Ana içeriğe geç
ACN Iris WG4K Motherboard Replacement
Neye ihtiyacın var
  1. ACN Iris WG4K Motherboard Replacement, Handset: adım 1, 2 resimden 1. ACN Iris WG4K Motherboard Replacement, Handset: adım 1, 2 resimden 2.
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Motherboard Replacement, Lower Case: adım 2, 1 resimden 1.
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Motherboard Replacement: adım 3, 2 resimden 1. ACN Iris WG4K Motherboard Replacement: adım 3, 2 resimden 2.
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Motherboard Replacement: adım 4, 3 resimden 1. ACN Iris WG4K Motherboard Replacement: adım 4, 3 resimden 2. ACN Iris WG4K Motherboard Replacement: adım 4, 3 resimden 3.
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Motherboard Replacement: adım 5, 2 resimden 1. ACN Iris WG4K Motherboard Replacement: adım 5, 2 resimden 2.
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Motherboard Replacement: adım 6, 1 resimden 1.
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Motherboard Replacement, Motherboard: adım 7, 1 resimden 1.
  8. ACN Iris WG4K Motherboard Replacement: adım 8, 2 resimden 1. ACN Iris WG4K Motherboard Replacement: adım 8, 2 resimden 2.
    • Firmly grasp the black port wall.
    • Pull up and push out to remove it from the lower case.
  9. ACN Iris WG4K Motherboard Replacement: adım 9, 1 resimden 1.
    • Gently lift the motherboard out of the lower case.
Sonuç
Itze Kenney
1.066 İtibar
9 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 20-4, Remmell Spring 2017 USF Tampa, Team 20-4, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S20G4
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 328
