Ana içeriğe geç
ACN Iris WG4K Speakers Replacement
Neye ihtiyacın var
  1. ACN Iris WG4K Speakers Replacement, Handset: adım 1, 2 resimden 1. ACN Iris WG4K Speakers Replacement, Handset: adım 1, 2 resimden 2.
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Speakers Replacement, Lower Case: adım 2, 1 resimden 1.
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Speakers Replacement: adım 3, 2 resimden 1. ACN Iris WG4K Speakers Replacement: adım 3, 2 resimden 2.
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Speakers Replacement: adım 4, 3 resimden 1. ACN Iris WG4K Speakers Replacement: adım 4, 3 resimden 2. ACN Iris WG4K Speakers Replacement: adım 4, 3 resimden 3.
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Speakers Replacement: adım 5, 2 resimden 1. ACN Iris WG4K Speakers Replacement: adım 5, 2 resimden 2.
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Speakers Replacement: adım 6, 1 resimden 1.
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Speakers Replacement, Keypad Ribbon Cable: adım 7, 1 resimden 1.
  8. ACN Iris WG4K Speakers Replacement: adım 8, 2 resimden 1. ACN Iris WG4K Speakers Replacement: adım 8, 2 resimden 2.
    • Gently lift up on the upper case to separate it from the keypad/speaker panel.
    • The ribbon cable is highlighted by the red rectangle.
    • The 2-pin JST connectors are highlighted by the orange squares.
  9. ACN Iris WG4K Speakers Replacement: adım 9, 3 resimden 1. ACN Iris WG4K Speakers Replacement: adım 9, 3 resimden 2. ACN Iris WG4K Speakers Replacement: adım 9, 3 resimden 3.
    • Disconnect the ribbon cable from its insulation-displacement connector by flipping up the black plastic clip.
    • Gently pull the ribbon cable out of its insulation-displacement connector.
  10. ACN Iris WG4K Speakers Replacement, Speakers: adım 10, 3 resimden 1. ACN Iris WG4K Speakers Replacement, Speakers: adım 10, 3 resimden 2. ACN Iris WG4K Speakers Replacement, Speakers: adım 10, 3 resimden 3.
    • Disconnect the two white 2-pin JST connectors from the keypad/speaker circuit board by tugging gently until they release.
  11. ACN Iris WG4K Speakers Replacement: adım 11, 2 resimden 1. ACN Iris WG4K Speakers Replacement: adım 11, 2 resimden 2.
    • The red markers indicate the four plastic clips arranged around the base of each speaker housing.
    • Use a plastic spudger to push in the four plastic clips.
  12. ACN Iris WG4K Speakers Replacement: adım 12, 2 resimden 1. ACN Iris WG4K Speakers Replacement: adım 12, 2 resimden 2.
    • Once both speakers have been unclipped, gently pull the wire through the housing .
  13. ACN Iris WG4K Speakers Replacement: adım 13, 3 resimden 1. ACN Iris WG4K Speakers Replacement: adım 13, 3 resimden 2. ACN Iris WG4K Speakers Replacement: adım 13, 3 resimden 3.
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (6 mm)
    • Gently lift up the black cover to expose the now freed speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Itze Kenney
1.066 İtibar
9 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 20-4, Remmell Spring 2017 USF Tampa, Team 20-4, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S20G4
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 212
