Ana içeriğe geç
AEE Mach 1 Battery Replacement
  1. AEE Mach 1 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure that your device is powered off before doing any work.
    • The battery is located at the back of the drone, on the opposite end of the drone from the camera.
    • There are two tabs on the edge of each side of the battery.
    FixBot'a Sor
    Yorum Ekle
  2. AEE Mach 1 Battery Replacement: adım 2, 1 resimden 1.
    • To remove the battery, simply grip the battery by the tabs, press down on both tabs, and pull the battery out.
    FixBot'a Sor
    Yorum Ekle
  3. AEE Mach 1 Battery Replacement: adım 3, 1 resimden 1.
    • To replace the battery, simply slide it back into its place until the tabs click back into place. If you are having trouble doing this, you may be putting it in upside down. Try flipping it over and trying again.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patrick Lewis
394 İtibar
2 adet Kılavuz yazıldı
3Kılavuz Yorumları
purchase the aee mach 1 but it has no battery
Ulysses aka UL Salett - Yanıt Paylaş
How do I get a new battery where do I look
haroldlknight55 - Yanıt Paylaş
Hi, how do a o get a battery?
Nivaldo Santos - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 1,604
