Ana içeriğe geç
AEE Mach 1 Drone Propeller Replacement
    1. AEE Mach 1 Drone Propeller Replacement, Propeller: adım 1, 1 resimden 1.
      • Make sure your drone is powered off and the battery is removed from the drone.
      • Identify the defective propeller on your drone.
      • Each propeller is marked as either 'A' or 'B'. Make sure the new propeller matches the old one.
      FixBot'a Sor
      Yorum Ekle
    2. AEE Mach 1 Drone Propeller Replacement: adım 2, 1 resimden 1.
      • In the center of each propeller, near the base, there are two arrows.
      • The symbol circled in red indicates the direction to "unlock" the propeller from the drone; this symbol indicates the direction to unscrew the rotor off of its mount.
      • The symbol circled in orange indicates the direction to "lock" the propeller onto the drone; this symbol indicates the direction to screw the rotor back onto the mount.
      FixBot'a Sor
      Yorum Ekle
    3. AEE Mach 1 Drone Propeller Replacement: adım 3, 1 resimden 1.
      • While keeping the motor under the propeller still, rotate the propeller in the direction shown to "unlock" the propeller.
      • The direction to unlock the propeller will depend on the letter labeled on the propeller.
      FixBot'a Sor
      Yorum Ekle
    4. AEE Mach 1 Drone Propeller Replacement: adım 4, 1 resimden 1.
      • Once you unscrew the propeller from the drone you will then be able to inspect the area for any additional damages.
      FixBot'a Sor
      Yorum Ekle
    5. AEE Mach 1 Drone Propeller Replacement: adım 5, 1 resimden 1.
      • Replace the defective propeller with one of the replacements that come with your drone, or you can attempt to fix the defective propeller.
      • To replace a propeller, simply place the rotor on the screw, and screw the propeller by rotating the propeller in the direction indicated by the arrow next to the “Lock” symbol.
      • The direction to lock the propeller on the drone will depend on the letter the propeller is labeled.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patrick Lewis
394 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 35
Her zaman: 1,105
