Ana içeriğe geç
AEG Electrolux Competence B33512 fan temperature switch replacement
Neye ihtiyacın var
  1. AEG Electrolux Competence B33512 fan temperature switch replacement, fan temperature switch: adım 1, 2 resimden 1. AEG Electrolux Competence B33512 fan temperature switch replacement, fan temperature switch: adım 1, 2 resimden 2.
    • All out the mains plug first as it is life-threatening to work on an open device which is still connected to the power.
    • Remove both screws that are used to hold the oven in place
    • Cautiously pull out the oven and place it on a small table. Be prepared for medium weight and use the handles in the middle of the oven on both sides.
  2. AEG Electrolux Competence B33512 fan temperature switch replacement: adım 2, 1 resimden 1.
    • Remove the two screws,
    • now slide the top metal sheet to the rear end of the oven
    • until you are able to lift the front edge of it and remove it entirely.
  3. AEG Electrolux Competence B33512 fan temperature switch replacement: adım 3, 3 resimden 1. AEG Electrolux Competence B33512 fan temperature switch replacement: adım 3, 3 resimden 2. AEG Electrolux Competence B33512 fan temperature switch replacement: adım 3, 3 resimden 3.
    • Cautiously pull out the ends of both white cables
    • Also pull out the light blue ones
    • This is the switch, hidden in cables
  4. AEG Electrolux Competence B33512 fan temperature switch replacement: adım 4, 1 resimden 1.
    • Now put in the new switch and pay attention that it doesn't touch any metal surfaces that may get hot
  5. AEG Electrolux Competence B33512 fan temperature switch replacement: adım 5, 2 resimden 1. AEG Electrolux Competence B33512 fan temperature switch replacement: adım 5, 2 resimden 2.
    • If the heating and the light don't work after reassembling the oven, press a button or re-set the clock to its actual time. The heating should immediately start then.
Sonuç
To reassemble your device, follow these instructions in reverse order
3 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bjarne dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Bjarne
388 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Legend svaka čast na pomoći.
JARE - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 32
Son 30 gün: 218
Her zaman: 7,704
