Ana içeriğe geç
AEG Electrolux FM72 Disassembly for cleaning
Neye ihtiyacın var
  1. AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: adım 1, 3 resimden 1. AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: adım 1, 3 resimden 2. AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: adım 1, 3 resimden 3.
    • Open the lid by pressing the grey button and lifting it away.
    • Clean each of the plastic parts with soap and water, and then leave them out to dry.
  2. AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: adım 2, 3 resimden 1. AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: adım 2, 3 resimden 2. AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: adım 2, 3 resimden 3.
    • Follow these steps to open the electronic casing.
    • Remove the four screws as shown in picture two.
    • A long Phillips screwdriver is needed for step two.
    • Remove the fifth screw at the bottom as shown in picture three.
  3. AEG Electrolux FM72 Disassembly for cleaning: adım 3, 3 resimden 1. AEG Electrolux FM72 Disassembly for cleaning: adım 3, 3 resimden 2. AEG Electrolux FM72 Disassembly for cleaning: adım 3, 3 resimden 3.
    • Gently pry the device open, using an iSesamo opener.
    • Now the I/O button can be removed.
    • Completely replacing this entire part requires desoldering wire connections.
  4. AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: adım 4, 2 resimden 1. AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: adım 4, 2 resimden 2.
    • Now the electronic components can be cleaned using an air compressor.
    • In picture one, you can see the PCBs. Under the PCB, you'll see blue batteries. These are 2 x 3 AA rechargeable batteries .
    • If the dust bag needs to be replaced, remove its securing screws.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kevin D
7.276 İtibar
21 adet Kılavuz yazıldı
3 Yorum
Hello
How can i repair the electric wire on this device please ?
Heloise - Yanıt
Hallo
Which electric wire do you mean? Can you send in a picture? Does it need soldering?
Kind regards
Kevin
Kevin D - Yanıt
How can I disassemble the motor parts for cleaning?
wongkapo0611 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 28
Her zaman: 6,469
