Ana içeriğe geç
AKASO KingPad A90 Rear Speaker Replacement
Neye ihtiyacın var
  1. AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: adım 1, 3 resimden 1. AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: adım 1, 3 resimden 2. AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: adım 1, 3 resimden 3.
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Rear Speaker Replacement: adım 2, 3 resimden 1. AKASO KingPad A90 Rear Speaker Replacement: adım 2, 3 resimden 2. AKASO KingPad A90 Rear Speaker Replacement: adım 2, 3 resimden 3.
    • Plug in soldering iron and let it warm up for ten minutes.
    • Locate the speaker solder points and note where it is attached to the motherboard.
    • Solder the old speaker out of its mark. (Touch the tip of the solder iron to the soldering point).
  3. AKASO KingPad A90 Rear Speaker Replacement: adım 3, 3 resimden 1. AKASO KingPad A90 Rear Speaker Replacement: adım 3, 3 resimden 2. AKASO KingPad A90 Rear Speaker Replacement: adım 3, 3 resimden 3.
    • Solder the new speaker onto the points where the old speaker was.
  4. AKASO KingPad A90 Rear Speaker Replacement: adım 4, 3 resimden 1. AKASO KingPad A90 Rear Speaker Replacement: adım 4, 3 resimden 2. AKASO KingPad A90 Rear Speaker Replacement: adım 4, 3 resimden 3.
    • Replace the back cover with the new rear speaker unit in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
Bitiş Çizgisi
camchristo
71 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 üyesi
UMASSD-VIJAYBHASKAR-S15S4G6
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 366
