Ana içeriğe geç
AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement
Neye ihtiyacın var
  1. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: adım 1, 3 resimden 1. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: adım 1, 3 resimden 2. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: adım 1, 3 resimden 3.
    • Remove screws
    • Insert spudger tool on the middle of the left side, between the white and black plastic
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed
    • Pull off the back cover
  2. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: adım 2, 3 resimden 1. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: adım 2, 3 resimden 2. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: adım 2, 3 resimden 3.
    • Remove the broken volume rocker/power button unit.
    • Place the new part into the empty slot.
  3. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: adım 3, 3 resimden 1. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: adım 3, 3 resimden 2. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: adım 3, 3 resimden 3.
    • Gently press the speaker into place.
    • Replace the back cover with the new part in place.
    • Be careful to not let the volume rocker unit fall out of place.
    • Replace the screws.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Miles
260 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 üyesi
UMASSD-VIJAYBHASKAR-S15S4G6
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 511
