Ana içeriğe geç
APEX AP-GS918 Camera Replacement
Neye ihtiyacın var
  1. APEX AP-GS918 Camera Replacement, Power/Volume Button: adım 1, 3 resimden 1. APEX AP-GS918 Camera Replacement, Power/Volume Button: adım 1, 3 resimden 2. APEX AP-GS918 Camera Replacement, Power/Volume Button: adım 1, 3 resimden 3.
    • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
    FixBot'a Sor
    Yorum Ekle
  2. APEX AP-GS918 Camera Replacement: adım 2, 3 resimden 1. APEX AP-GS918 Camera Replacement: adım 2, 3 resimden 2. APEX AP-GS918 Camera Replacement: adım 2, 3 resimden 3.
    • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
    • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
    • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
    FixBot'a Sor
    Yorum Ekle
  3. APEX AP-GS918 Camera Replacement: adım 3, 2 resimden 1. APEX AP-GS918 Camera Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
    FixBot'a Sor
    Yorum Ekle
  4. APEX AP-GS918 Camera Replacement, Camera: adım 4, 3 resimden 1. APEX AP-GS918 Camera Replacement, Camera: adım 4, 3 resimden 2. APEX AP-GS918 Camera Replacement, Camera: adım 4, 3 resimden 3.
    • Remove the black electrical tape covering the motherboard components along with the black cloth tape covering the camera itself.
    • Be careful when removing the black cloth tape from the camera on the top left corner of the tablet. The tape will likely stick and pull the camera with it.
    FixBot'a Sor
    Yorum Ekle
  5. APEX AP-GS918 Camera Replacement: adım 5, 3 resimden 1. APEX AP-GS918 Camera Replacement: adım 5, 3 resimden 2. APEX AP-GS918 Camera Replacement: adım 5, 3 resimden 3.
    • Locate the white and gray connector that's holding the camera in place.
    • Use the black nylon spudger to eject the camera from its slot by gently lifting the gray clip vertically 90°.
    • Once ejected, you may easily remove the camera by pulling it from its slot.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Megan Lozicki
416 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S9G1
3 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 37
Her zaman: 577
