Ana içeriğe geç
APEX AP-GS918 Speakers Replacement
Neye ihtiyacın var
    1. APEX AP-GS918 Speakers Replacement, Power/Volume Button: adım 1, 3 resimden 1. APEX AP-GS918 Speakers Replacement, Power/Volume Button: adım 1, 3 resimden 2. APEX AP-GS918 Speakers Replacement, Power/Volume Button: adım 1, 3 resimden 3.
      • To begin, locate the two 4.9mm Phillips #00 screws at the top corners of the case and remove them.
      FixBot'a Sor
      Yorum Ekle
    2. APEX AP-GS918 Speakers Replacement: adım 2, 3 resimden 1. APEX AP-GS918 Speakers Replacement: adım 2, 3 resimden 2. APEX AP-GS918 Speakers Replacement: adım 2, 3 resimden 3.
      • Squeeze the plastic opening tool in between the seam where the screen joins the plastic case.
      • Begin separating the bottom of the case from the screen by carefully going around the whole edge of the case and slowly prying it apart.
      • Be careful when separating the lids because the wires holding the speaker to the motherboard are very short.
      FixBot'a Sor
      Yorum Ekle
    3. APEX AP-GS918 Speakers Replacement: adım 3, 2 resimden 1. APEX AP-GS918 Speakers Replacement: adım 3, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Carefully place the bottom lid next to the screen case. The power/speaker buttons should be visible at the corner of the lid. Remove the buttons with the tweezers.
      FixBot'a Sor
      Yorum Ekle
    1. APEX AP-GS918 Speakers Replacement, Speakers: adım 4, 3 resimden 1. APEX AP-GS918 Speakers Replacement, Speakers: adım 4, 3 resimden 2. APEX AP-GS918 Speakers Replacement, Speakers: adım 4, 3 resimden 3.
      • The speaker is attached to the bottom lid with with a small amount of glue and the wires are soldered to the motherboard.
      • In order to remove the speaker you will have to desolder the wires connected to the motherboard.
      • Start by peeling back the black electrical tape covering the motherboard components
      • You will also need to remove the black cloth tape covering the wire contact points.
      FixBot'a Sor
      Yorum Ekle
    2. APEX AP-GS918 Speakers Replacement: adım 5, 2 resimden 1. APEX AP-GS918 Speakers Replacement: adım 5, 2 resimden 2.
      • Now that the contacts are exposed, you can desolder them.
      • Make sure to allow ample time (at least 5-8 minutes or more) for the soldering iron to heat up. Otherwise, the solder won't melt.
      • Touch the hot iron to the contact points and gently pull on the wires to loosen them from the solder. They should release easily.
      • Make sure not to touch the contact points after desoldering them because they will remain very hot for a short while afterwards.
      • The speaker can now be removed. You may need to pull it with some force since there is a small bead of hot glue holding the speaker to its housing
      FixBot'a Sor
      Yorum Ekle
Sonuç
Megan Lozicki
416 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-1, Leahy Winter 2015 USF Tampa, Team 9-1, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S9G1
3 Üyeler
29 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 39
Her zaman: 562
