Ana içeriğe geç
APEX TM785CH Battery Replacement
Neye ihtiyacın var
  1. APEX TM785CH Battery Replacement, Back Casing: adım 1, 2 resimden 1. APEX TM785CH Battery Replacement, Back Casing: adım 1, 2 resimden 2.
    • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
    • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
    • Move along the top edge of the tablet and repeat the step above.
    • Pull the back cover away from the tablet body to completely remove it.
  2. APEX TM785CH Battery Replacement, Battery: adım 2, 2 resimden 1. APEX TM785CH Battery Replacement, Battery: adım 2, 2 resimden 2.
    • With the back cover removed, you can now see the battery.
    • You will need a soldering/desoldering kit to desolder the 3 battery leads to the circuit board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brian Graschel
823 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-1, Williams Spring 2015 Baylor, Team 4-1, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G1
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 2,109
