Ana içeriğe geç
APS Tech 101629 Channel Switch Replacement
Neye ihtiyacın var
  1. APS Tech 101629 Channel Switch Replacement, External Casing: adım 1, 3 resimden 1. APS Tech 101629 Channel Switch Replacement, External Casing: adım 1, 3 resimden 2. APS Tech 101629 Channel Switch Replacement, External Casing: adım 1, 3 resimden 3.
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Channel Switch Replacement: adım 2, 2 resimden 1. APS Tech 101629 Channel Switch Replacement: adım 2, 2 resimden 2.
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Channel Switch Replacement: adım 3, 2 resimden 1. APS Tech 101629 Channel Switch Replacement: adım 3, 2 resimden 2.
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Channel Switch Replacement: adım 4, 1 resimden 1.
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Channel Switch Replacement: adım 5, 2 resimden 1. APS Tech 101629 Channel Switch Replacement: adım 5, 2 resimden 2.
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Channel Switch Replacement, Channel Switch: adım 6, 2 resimden 1. APS Tech 101629 Channel Switch Replacement, Channel Switch: adım 6, 2 resimden 2.
    • Find the conjoined ID cable wires that are colored black, orange, and yellow.
    • Lift white portion of cable wires to disconnect it.
  7. APS Tech 101629 Channel Switch Replacement: adım 7, 3 resimden 1. APS Tech 101629 Channel Switch Replacement: adım 7, 3 resimden 2. APS Tech 101629 Channel Switch Replacement: adım 7, 3 resimden 3.
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alexis Weckel
140 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-60, Amido Spring 2011 Cal Poly, Team 24-60, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G60
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 817
