Ana içeriğe geç
APS Tech 101629 Exhaust Fan Replacement
Neye ihtiyacın var
    1. APS Tech 101629 Exhaust Fan Replacement, External Casing: adım 1, 3 resimden 1. APS Tech 101629 Exhaust Fan Replacement, External Casing: adım 1, 3 resimden 2. APS Tech 101629 Exhaust Fan Replacement, External Casing: adım 1, 3 resimden 3.
      • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
      FixBot'a Sor
      Yorum Ekle
    2. APS Tech 101629 Exhaust Fan Replacement: adım 2, 2 resimden 1. APS Tech 101629 Exhaust Fan Replacement: adım 2, 2 resimden 2.
      • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. APS Tech 101629 Exhaust Fan Replacement: adım 3, 2 resimden 1. APS Tech 101629 Exhaust Fan Replacement: adım 3, 2 resimden 2.
      • Flip the device right side up.
      • Gently slide the casing upwards and off the hard drive.
      FixBot'a Sor
      Yorum Ekle
    4. APS Tech 101629 Exhaust Fan Replacement: adım 4, 1 resimden 1.
      • Flip device upside down again.
      • Gently pry the bottom gray casing away from the device.
      FixBot'a Sor
      Yorum Ekle
    5. APS Tech 101629 Exhaust Fan Replacement: adım 5, 2 resimden 1. APS Tech 101629 Exhaust Fan Replacement: adım 5, 2 resimden 2.
      • Rotate so the back of the device is facing you.
      • Gently pry the back casing away.
      • When the back casing is removed, the fan will become loose.
      FixBot'a Sor
      Yorum Ekle
    1. APS Tech 101629 Exhaust Fan Replacement, Channel Switch: adım 6, 2 resimden 1. APS Tech 101629 Exhaust Fan Replacement, Channel Switch: adım 6, 2 resimden 2.
      • Find the conjoined ID cable wires that are colored black, orange, and yellow.
      • Lift white portion of cable wires to disconnect it.
      FixBot'a Sor
      Yorum Ekle
    2. APS Tech 101629 Exhaust Fan Replacement: adım 7, 3 resimden 1. APS Tech 101629 Exhaust Fan Replacement: adım 7, 3 resimden 2. APS Tech 101629 Exhaust Fan Replacement: adım 7, 3 resimden 3.
      • At this point, the fan is loose and can be easily moved but not disconnected.
      • Using the spudger, depress the pressure holders at all four corners of the fan.
      • Take out the fan and its cords, by pulling it outward from its cavity within the device.
      FixBot'a Sor
      Yorum Ekle
    1. APS Tech 101629 Exhaust Fan Replacement, Power Switch: adım 8, 2 resimden 1. APS Tech 101629 Exhaust Fan Replacement, Power Switch: adım 8, 2 resimden 2.
      • Depress 2 pressure holds on each side of the power switch.
      • Press out the back of the device.
      FixBot'a Sor
      Yorum Ekle
    2. APS Tech 101629 Exhaust Fan Replacement: adım 9, 2 resimden 1. APS Tech 101629 Exhaust Fan Replacement: adım 9, 2 resimden 2.
      • Remove all four 4 connections from the power switch.
      • Remember that the straight connections are on the far side, while the L-shaped connections are on the near side, and that both yellow connections are on top. This is helpful for reassembly.
      • These are very hard to get off, use patience and wiggling.
      FixBot'a Sor
      Yorum Ekle
    1. APS Tech 101629 Exhaust Fan Replacement, Exhaust Fan: adım 10, 1 resimden 1.
      • Remove temperature guage.
      FixBot'a Sor
      Yorum Ekle
    2. APS Tech 101629 Exhaust Fan Replacement: adım 11, 3 resimden 1. APS Tech 101629 Exhaust Fan Replacement: adım 11, 3 resimden 2. APS Tech 101629 Exhaust Fan Replacement: adım 11, 3 resimden 3.
      • Move the exhaust fan out of the way so you can access its control cord.
      • Use the spudger to depress the hold on the fan cord.
      • Gently pull fan cord from connection and remove fan completely.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Patrick Meyer
83 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-60, Amido Spring 2011 Cal Poly, Team 24-60, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G60
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 1,106
