Ana içeriğe geç
APS Tech 101629 SCSI Connections Replacement
Neye ihtiyacın var
  1. APS Tech 101629 SCSI Connections Replacement, External Casing: adım 1, 3 resimden 1. APS Tech 101629 SCSI Connections Replacement, External Casing: adım 1, 3 resimden 2. APS Tech 101629 SCSI Connections Replacement, External Casing: adım 1, 3 resimden 3.
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 SCSI Connections Replacement: adım 2, 2 resimden 1. APS Tech 101629 SCSI Connections Replacement: adım 2, 2 resimden 2.
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 SCSI Connections Replacement: adım 3, 2 resimden 1. APS Tech 101629 SCSI Connections Replacement: adım 3, 2 resimden 2.
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 SCSI Connections Replacement: adım 4, 1 resimden 1.
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 SCSI Connections Replacement: adım 5, 2 resimden 1. APS Tech 101629 SCSI Connections Replacement: adım 5, 2 resimden 2.
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: adım 6, 2 resimden 1. APS Tech 101629 SCSI Connections Replacement, Internal Drive Component: adım 6, 2 resimden 2.
    • Flip so device is upside down.
    • Remove 4 screws with Phillips #1 screw driver.
    • Be sure to save the washers that seperate the screws from the baseplate for reassembly.
  7. APS Tech 101629 SCSI Connections Replacement: adım 7, 2 resimden 1. APS Tech 101629 SCSI Connections Replacement: adım 7, 2 resimden 2.
    • Slide the internal drive component away from the back of the device.
    • Remove the connections from the back of the internal component in the order of your choosing, we suggest left to right. The connections are:
    • Audio Connection
    • SCSI ID
    • Terminate On
    • SCSI Connection
    • DC Input (power)
  8. APS Tech 101629 SCSI Connections Replacement, SCSI Connections: adım 8, 3 resimden 1. APS Tech 101629 SCSI Connections Replacement, SCSI Connections: adım 8, 3 resimden 2. APS Tech 101629 SCSI Connections Replacement, SCSI Connections: adım 8, 3 resimden 3.
    • Remove the four Phillips #1 Screws from back panel.
    • Once the screws are removed, the two connections are easily removed from the body.
Sonuç
Patrick Meyer
83 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-60, Amido Spring 2011 Cal Poly, Team 24-60, Amido Spring 2011 üyesi
CPSU-AMIDO-S11S24G60
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 875
