Ana içeriğe geç
ARRIS Surfboard SB6183 Modem Heatsink Replacement
Neye ihtiyacın var
  1. ARRIS Surfboard SB6183 Modem Heatsink Replacement, Heatsink: adım 1, 3 resimden 1. ARRIS Surfboard SB6183 Modem Heatsink Replacement, Heatsink: adım 1, 3 resimden 2. ARRIS Surfboard SB6183 Modem Heatsink Replacement, Heatsink: adım 1, 3 resimden 3.
    • Use pliers to remove the thin nut and washer from the coax port.
  2. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 2, 1 resimden 1.
    • Remove the single 9mm Torx screw using a Torx T10 screwdriver.
  3. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 3, 3 resimden 1. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 3, 3 resimden 2. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 3, 3 resimden 3.
    • Use a spudger to press the plastic retention clip inward and toward the center of the modem.
    • The plastic clip is hidden in a hole beneath the sticker on the bottom of the case.
  4. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 4, 3 resimden 1. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 4, 3 resimden 2. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 4, 3 resimden 3.
    • Slide the left side panel of the modem toward the back, then up and out at a shallow angle.
  5. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 5, 3 resimden 1. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 5, 3 resimden 2. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 5, 3 resimden 3.
    • There are small plastic tabs on either side of the clear LED diffuser. Use the flat end of a spudger to pry both of them outwards slightly.
  6. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 6, 2 resimden 1. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 6, 2 resimden 2.
    • Rotate the diffuser upward to unlatch it.
    • You may need to hold the plastic tabs on either side out of the way.
  7. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 7, 2 resimden 1. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 7, 2 resimden 2.
    • To remove the board, lift the front end up slightly and gently pull toward the front to remove.
    • You may need to wiggle the board loose from the thin clips on either side.
  8. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 8, 1 resimden 1.
    • If your device doesn't have a heatsink, skip this step. To remove an existing heatsink, hold the board steady and use pliers to gently twist it off.
  9. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 9, 1 resimden 1.
    • Peel off the paper backing that protects the thermally conductive adhesive to prepare the heatsink for application.
  10. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 10, 2 resimden 1. ARRIS Surfboard SB6183 Modem Heatsink Replacement: adım 10, 2 resimden 2.
    • Center the sticky side of the heatsink over the bare chip, then press down gently to secure it.
    • Make sure the heatsink is stuck in place and will not slide off.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Thank you for this review, helped me to open it. The only thing i did differently is peeled oof the sticker from the bottom - carefully, so not to damage it. Why do u place the heatsink on that specific tiny chip - is it the one that heats up the most? My feeling when opening it was that the RF part was the hottest.
Andru Nl - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 3,617
