Ana içeriğe geç
ASUS X540BA-BB61-CB Screen Replacement
Neye ihtiyacın var
  1. ASUS  X540BA-BB61-CB Screen Replacement, Power Down the Laptop: adım 1, 2 resimden 1. ASUS  X540BA-BB61-CB Screen Replacement, Power Down the Laptop: adım 1, 2 resimden 2.
    • Power off the device and unplug it from the charging cord.
  2. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel Frame: adım 2, 2 resimden 1. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel Frame: adım 2, 2 resimden 2.
    • Use a spudger to remove the plastic screw covers in the bottom right and left corner of the screen.
    • Remove the two Phillips #2 (M2.5 x4)mm flat head screws in the two bottom corners under the screw covers.
    • Then remove the bezel frame with a spudger.
  3. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Bezel: adım 3, 1 resimden 1.
    • Once these screws are removed, carefully remove the bezel by the inner edge working your way around the perimeter.
    • Be careful to undo the clips as you remove the bezel and don't yank it off. The bezel is flexible but can break.
  4. ASUS  X540BA-BB61-CB Screen Replacement, Remove the grounding tape: adım 4, 1 resimden 1.
    • Remove the grounding tape covering the screws in the four corners of the screen.
    • Use a Phillips #2 screwdriver to remove four (M2 x 4) mm screws from the four corners of the screen that hold the LCD panel in place.
  5. ASUS  X540BA-BB61-CB Screen Replacement, Remove the Screen: adım 5, 1 resimden 1.
    • Peel off one side of the tape and remove the two bottom screws.
    • It is important to remember that the video cable is secured with cleared tape.
    • Peel off the tape, gently slide the cable out and remove the LCD Panel. Take the new LCD panel and place it on the keyboard.
    • Gently slide the connector to the jack secured with cleared tape with both hands.
Sonuç
David Shodipo
1 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 18
Son 30 gün: 68
Her zaman: 2,517
