Ana içeriğe geç
ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement
Neye ihtiyacın var
  1. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement, Lower Case: adım 1, 1 resimden 1.
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: adım 2, 1 resimden 1.
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: adım 4, 1 resimden 1.
    • Use the iFixit opening tool to remove the back of the laptop.
  5. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: adım 5, 1 resimden 1.
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
  6. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement, Audio Ports: adım 6, 1 resimden 1.
    • Remove the four 3mm J1 screws attached to the audio cards.
  7. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: adım 7, 2 resimden 1. ASUS Chromebook C100PA-RBRKT07 Audio Ports Replacement: adım 7, 2 resimden 2.
    • Lift and remove the audio cards.
    • Separate the wires from the motherboard.
Sonuç
Tomas Martinez
185 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G4, White Winter 2019 Cal Poly, Team S19-G4, White Winter 2019 üyesi
CPSU-WHITE-W19S19G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 149
