Ana içeriğe geç
ASUS Chromebook C100PA-RBRKT07 Battery Replacement
Neye ihtiyacın var
  1. ASUS Chromebook C100PA-RBRKT07 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: adım 2, 1 resimden 1.
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the T5 screwdriver to remove the 6 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: adım 4, 1 resimden 1.
    • Use the iFixit opening tool to pry the backing of the device off.
  5. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: adım 5, 1 resimden 1.
    • Use the tweezers to separate the cables from the motherboard.
    • You need to reach inside and peel some tape to disconnect the wire.
  6. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: adım 6, 1 resimden 1.
    • Use the JIS1 screwdriver to remove the four 2.1 mm screws around the audio cards.
  7. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: adım 7, 2 resimden 1. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: adım 7, 2 resimden 2.
    • Gently disconnect the audio cards, exposing the battery.
  8. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: adım 8, 1 resimden 1.
    • Use the J00 screwdriver to remove the three 1.7 mm battery screws.
  9. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: adım 9, 3 resimden 1. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: adım 9, 3 resimden 2. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: adım 9, 3 resimden 3.
    • Grip the battery and remove it from the device.
    • Remove the battery cable out of the motherboard by lifting the battery cables.
Sonuç
Tiffany Foo
289 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G4, White Winter 2019 Cal Poly, Team S19-G4, White Winter 2019 üyesi
CPSU-WHITE-W19S19G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 399
