Ana içeriğe geç
ASUS Chromebook C100PA-RBRKT07 Lower Case Replacement
Neye ihtiyacın var
  1. ASUS Chromebook C100PA-RBRKT07 Lower Case Replacement, Lower Case: adım 1, 1 resimden 1.
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Lower Case Replacement: adım 2, 1 resimden 1.
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Lower Case Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Lower Case Replacement: adım 4, 1 resimden 1.
    • Use the iFixit opening tool to remove the back of the laptop.
  5. ASUS Chromebook C100PA-RBRKT07 Lower Case Replacement: adım 5, 1 resimden 1.
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
Sonuç
Tiffany Foo
289 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G4, White Winter 2019 Cal Poly, Team S19-G4, White Winter 2019 üyesi
CPSU-WHITE-W19S19G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 241
