Ana içeriğe geç
ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement
Neye ihtiyacın var
  1. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Lower Case: adım 1, 1 resimden 1.
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: adım 2, 1 resimden 1.
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the T5 screwdriver to remove the six 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: adım 4, 1 resimden 1.
    • Use the iFixit opening tool to remove the back of the laptop.
  5. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: adım 5, 1 resimden 1.
    • Use the blunt nose tweezers to separate the keyboard from the internal components.
  6. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Trackpad: adım 6, 2 resimden 1. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement, Trackpad: adım 6, 2 resimden 2.
    • Grip the keyboard and carefully pull it off the device.
  7. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: adım 7, 2 resimden 1. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: adım 7, 2 resimden 2.
    Satın Al
    • On the back of the keyboard assembly, use the tweezers to pull the white cable from the track pad.
  8. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: adım 8, 1 resimden 1.
    • Remove the three 1 mm screws from the track pad using the JIS 00 screwdriver.
  9. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: adım 9, 2 resimden 1. ASUS Chromebook C100PA-RBRKT07 Trackpad Replacement: adım 9, 2 resimden 2.
    • Grip the track pad with the tweezers and slide it up and out of the keyboard assembly.
Sonuç
Lauren Schirle
205 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S19-G4, White Winter 2019 Cal Poly, Team S19-G4, White Winter 2019 üyesi
CPSU-WHITE-W19S19G4
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 359
