Giriş
This replacement guide will show you how to access and remove the battery in your Chromebook.
Neye ihtiyacın var
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
2 farklı kişi bu kılavuzu tamamladı.
