Ana içeriğe geç
ASUS Chromebook C200MA DS01 Motherboard Replacement
Neye ihtiyacın var
  1. ASUS Chromebook C200MA DS01 Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Motherboard Replacement, Battery Connection: adım 4, 3 resimden 1. ASUS Chromebook C200MA DS01 Motherboard Replacement, Battery Connection: adım 4, 3 resimden 2. ASUS Chromebook C200MA DS01 Motherboard Replacement, Battery Connection: adım 4, 3 resimden 3.
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Disconnect the USB board ZIF (zero insertion force) connector located towards the bottom left of the motherboard.
    • Flip the ZIF connector retaining flap up using either a spudger or your fingers.
    • Pull gently on the ribbon cable to disconnect it from the motherboard.
  6. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 6, 3 resimden 1. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 6, 3 resimden 2. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 6, 3 resimden 3.
    • Disconnect the large keyboard and small touchpad ZIF connectors, both located in the middle of the bottom edge of the motherboard.
    • Flip both ZIF retaining flaps up using either a spudger or your fingers.
    • Gently pull on each ribbon cable to disconnect them from the motherboard.
  7. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 7, 2 resimden 1. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 7, 2 resimden 2.
    • Disconnect the speaker's black bundled cable connector (the cable is white, black and red).
    • Pinch the black bundled cable connector between your thumb and pointer finger and pull.
  8. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 8, 3 resimden 1. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 8, 3 resimden 2. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 8, 3 resimden 3.
    • Disconnect the screen cable connector located towards the top right of the motherboard.
    • Using a spudger, gently pry up the sides of the connector.
    • Pull off the connector with your hands.
  9. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 9, 2 resimden 1. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 9, 2 resimden 2.
    • Disconnect the black and white antenna cable connectors for the WiFi card. The connectors look like small buttons on the ends of colored wires.
    • Gently pry the cable connectors off with your fingers or a spudger.
    • These connections are button-like and will have a little resistance when removing.
  10. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the eight Phillips #0 4.7 mm screws.
    • Remove the Phillips #0 3.7 mm screw.
    • Remove the Phillips #0 2.8 mm screw.
  11. ASUS Chromebook C200MA DS01 Motherboard Replacement: adım 11, 1 resimden 1.
    • Lift the motherboard from the Chromebook.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Christopher Lim
779 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G4, Livingston Spring 2017 Cal Poly, Team S23-G4, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G4
4 Üyeler
19 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 2,045
