Giriş
This guide will take you through a step-by-step process for the removal of your Chromebook’s motherboard.
Neye ihtiyacın var
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Disconnect the USB board ZIF (zero insertion force) connector located towards the bottom left of the motherboard.
Flip the ZIF connector retaining flap up using either a spudger or your fingers.
Pull gently on the ribbon cable to disconnect it from the motherboard.
2 farklı kişi bu kılavuzu tamamladı.
