Ana içeriğe geç
ASUS Chromebook C200MA DS01 Speaker Replacement
Neye ihtiyacın var
  1. ASUS Chromebook C200MA DS01 Speaker Replacement, Back Panel: adım 1, 1 resimden 1.
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Speaker Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: adım 4, 3 resimden 1. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: adım 4, 3 resimden 2. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: adım 4, 3 resimden 3.
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery: adım 5, 2 resimden 1. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery: adım 5, 2 resimden 2.
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Speaker Replacement: adım 6, 1 resimden 1.
    • Pull out the battery.
  7. ASUS Chromebook C200MA DS01 Speaker Replacement, Speaker: adım 7, 2 resimden 1. ASUS Chromebook C200MA DS01 Speaker Replacement, Speaker: adım 7, 2 resimden 2.
    • Disconnect the speaker's black bundled cable connector on the motherboard.
    • The cables are red, white and black.
    • Pinch the black bundled cable connector between your thumb and pointer finger and pull.
  8. ASUS Chromebook C200MA DS01 Speaker Replacement: adım 8, 2 resimden 1. ASUS Chromebook C200MA DS01 Speaker Replacement: adım 8, 2 resimden 2.
    • Using your hands or the small plastic opening tool, pry the right speaker from the Chromebook.
    • There are small adhesives under the speakers that will provide moderate resistance.
  9. ASUS Chromebook C200MA DS01 Speaker Replacement: adım 9, 2 resimden 1. ASUS Chromebook C200MA DS01 Speaker Replacement: adım 9, 2 resimden 2.
    • Disconnect the USB port ZIF(zero insertion force) connector that partially covers the left speaker.
    • Flip the ZIF retaining flap up using a spudger or your fingers.
    • Pull gently on the ribbon cable to remove it from the connector.
  10. ASUS Chromebook C200MA DS01 Speaker Replacement: adım 10, 2 resimden 1. ASUS Chromebook C200MA DS01 Speaker Replacement: adım 10, 2 resimden 2.
    • Unravel the connecting cord between the two speakers.
  11. ASUS Chromebook C200MA DS01 Speaker Replacement: adım 11, 3 resimden 1. ASUS Chromebook C200MA DS01 Speaker Replacement: adım 11, 3 resimden 2. ASUS Chromebook C200MA DS01 Speaker Replacement: adım 11, 3 resimden 3.
    • Using the small plastic opening tool, pry the left speaker from the Chromebook.
    • Remove the speakers.
    • There are small adhesives that will provide moderate resistance.
Sonuç
Christopher Lim
779 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G4, Livingston Spring 2017 Cal Poly, Team S23-G4, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G4
4 Üyeler
19 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 8
Her zaman: 255
