Giriş
This guide will take you through a step-by-step process for the removal of your Chromebook’s touch pad.
Neye ihtiyacın var
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
Sonuç
