Ana içeriğe geç
ASUS Chromebook C200MA DS01 Touchpad Replacement
Neye ihtiyacın var
  1. ASUS Chromebook C200MA DS01 Touchpad Replacement, Back Panel: adım 1, 1 resimden 1.
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 3, 1 resimden 1.
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: adım 4, 3 resimden 1. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: adım 4, 3 resimden 2. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery Connection: adım 4, 3 resimden 3.
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: adım 5, 2 resimden 1. ASUS Chromebook C200MA DS01 Touchpad Replacement, Battery: adım 5, 2 resimden 2.
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 6, 1 resimden 1.
    • Pull out the battery.
  7. ASUS Chromebook C200MA DS01 Touchpad Replacement, Touchpad: adım 7, 1 resimden 1.
    • Locate the touchpad.
    • Locate the touch pad cable connector.
  8. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 8, 3 resimden 1. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 8, 3 resimden 2. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 8, 3 resimden 3.
    • Disconnect the touch pad ZIF(zero insertion force) connector.
    • Flip the flap up using a spudger or your fingers.
    • Pull gently on the ribbon cable to disconnect.
  9. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 9, 1 resimden 1.
    • Gently remove the adhesive on the touch pad ribbon cable.
  10. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 10, 3 resimden 1. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 10, 3 resimden 2. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 10, 3 resimden 3.
    • Gently remove the metallic tape from the touch pad only.
    • Try not to tear the tape, it can be re-used during reassembly.
  11. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 11, 1 resimden 1.
    • Remove the three 1.8 mm Phillips #00 screws.
  12. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 12, 2 resimden 1. ASUS Chromebook C200MA DS01 Touchpad Replacement: adım 12, 2 resimden 2.
    • Lift the far edge of the touch pad to remove it.
Sonuç
Christopher Lim
779 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G4, Livingston Spring 2017 Cal Poly, Team S23-G4, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G4
4 Üyeler
19 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 582
