Ana içeriğe geç
ASUS Chromebook C200MA DS01 Wireless Card Replacement
Neye ihtiyacın var
  1. ASUS Chromebook C200MA DS01 Wireless Card Replacement, Back Panel: adım 1, 1 resimden 1.
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Wireless Card Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Wireless Card Replacement: adım 3, 1 resimden 1.
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Wireless Card Replacement, Battery Connection: adım 4, 3 resimden 1. ASUS Chromebook C200MA DS01 Wireless Card Replacement, Battery Connection: adım 4, 3 resimden 2. ASUS Chromebook C200MA DS01 Wireless Card Replacement, Battery Connection: adım 4, 3 resimden 3.
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Wireless Card Replacement, Wireless Card: adım 5, 1 resimden 1.
    • Remove the silver 2.8 mm Phillips #0 screw from the wireless card.
  6. ASUS Chromebook C200MA DS01 Wireless Card Replacement: adım 6, 1 resimden 1.
    • Use a spudger to disconnect the white and black antenna cables connected to the wireless card.
  7. ASUS Chromebook C200MA DS01 Wireless Card Replacement: adım 7, 2 resimden 1. ASUS Chromebook C200MA DS01 Wireless Card Replacement: adım 7, 2 resimden 2.
    • Grab the wireless card between your thumb and index finger and pull directly away from the motherboard.
Sonuç
Christopher Lim
779 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S23-G4, Livingston Spring 2017 Cal Poly, Team S23-G4, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S23G4
4 Üyeler
19 adet Kılavuz yazıldı
Bir Yorum
Is this at all possible on Asus 204ma or Asus 214MA ?
Knoll - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 785
