Ana içeriğe geç
ASUS Chromebook C300MA-DH01 Battery Replacement
Neye ihtiyacın var
  1. ASUS Chromebook C300MA-DH01 Battery  Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the Chromebook over so the bottom of the device is facing up.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 2, 2 resimden 1. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 2, 2 resimden 2.
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom
    • (5) Five 6mm screws
    • (6) Six 8mm screws
    FixBot'a Sor
    Yorum Ekle
  3. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 3, 3 resimden 1. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 3, 3 resimden 2. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 3, 3 resimden 3.
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
    FixBot'a Sor
    Yorum Ekle
  4. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 4, 3 resimden 1. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 4, 3 resimden 2. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 4, 3 resimden 3.
    • Gently detach connecting cables:
    • Carefully flip up the large black tab.
    • Carefully flip up small white tab.
    • Remove the corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
    FixBot'a Sor
    Yorum Ekle
  5. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 5, 2 resimden 1. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 5, 2 resimden 2.
    • Using the JIS-J0 Screwdriver, remove the (6) six 6 mm screws from the battery.
    FixBot'a Sor
    Yorum Ekle
  6. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
amer khalil
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Passmore Fall 2017 USF Tampa, Team S2-G5, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S2G5
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 447
