Ana içeriğe geç
ASUS Chromebook C300MA-DH01 Battery Replacement
Neye ihtiyacın var
  1. ASUS Chromebook C300MA-DH01 Battery  Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 2, 2 resimden 1. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 2, 2 resimden 2.
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 3, 3 resimden 1. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 3, 3 resimden 2. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 3, 3 resimden 3.
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 4, 3 resimden 1. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 4, 3 resimden 2. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 4, 3 resimden 3.
    • Gently detach connecting cables:
    • Carefully flip up the large black tab.
    • Carefully flip up small white tab.
    • Remove the corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
  5. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 5, 2 resimden 1. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 5, 2 resimden 2.
    • Using the JIS-J0 Screwdriver, remove the (6) six 6 mm screws from the battery.
  6. ASUS Chromebook C300MA-DH01 Battery  Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
Sonuç
amer khalil
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Passmore Fall 2017 USF Tampa, Team S2-G5, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S2G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 197
