Ana içeriğe geç
ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement
Neye ihtiyacın var
  1. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement, Keyboard & Trackpad Assembly: adım 1, 1 resimden 1.
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: adım 2, 2 resimden 1. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: adım 2, 2 resimden 2.
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom:
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: adım 3, 3 resimden 1. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: adım 3, 3 resimden 2. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: adım 3, 3 resimden 3.
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: adım 4, 3 resimden 1. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: adım 4, 3 resimden 2. ASUS Chromebook C300MA-DH01 Keyboard & Trackpad Assembly Replacement: adım 4, 3 resimden 3.
    • Gently detach connecting cables.
    • Carefully flip up the large black tab.
    • Carefully flip up small white tab.
    • Remove the corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
Sonuç
Gina Altimari
401 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G5, Passmore Fall 2017 USF Tampa, Team S2-G5, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S2G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 165
