Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use a Philips #1 screwdriver to remove the nine screws from the back cover.
Turn the laptop over and open the display.
Insert the flat edge of the spudger into the crease of the keyboard cover.
While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
Slowly lift the cover open from the front of the laptop, but do not completely remove it.
Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
Disconnect the three data cables from the motherboard.
Remove the fully disconnected keyboard module from the laptop.
Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
Slide the drive out to the right of the laptop to disconnect from the motherboard.
