Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use a Philips #1 screwdriver to remove the nine screws from the back cover.
Turn the laptop over and open the display.
Insert the flat edge of the spudger into the crease of the keyboard cover.
While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
Slowly lift the cover open from the front of the laptop, but do not completely remove it.
Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
Disconnect the three data cables from the motherboard.
Remove the fully disconnected keyboard module from the laptop.
Remove the four screws that hold the hard drive in place with the Philips #1 screwdriver.
Remove the hard drive by sliding it to the right to disconnect it from the motherboard and lifting out.
Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
Slide the drive out to the right of the laptop to disconnect from the motherboard.
Remove the two screws securing the battery to the laptop case with a Phillips #1 screwdriver.
Lift the battery out and remove it:
Use your fingertips to evenly grip the battery on the left and right sides of the battery.
Pull straight up to lift the battery out of its place.
Locate the Network Interface Card (NIC) on the motherboard.
Gently disconnect the white and black wires by pulling it off of the NIC card. These wires should come off easy.
Remove the screws that are holding down the wireless network card with the Phillips #1 screwdriver.
Bu adımda kullanılan alet:Tweezers$4.99-
Remove the 9 screws from the motherboard using the Philips #1 screwdriver.
Disconnect the three cables attached to the motherboard.
The large, black cable is connected to the screen. Carefully wiggle the cable out by gripping the black tape with your fingers.
The cable for the fan and speaker use similar connectors. Use the black spudger or carefully grip the sides of each connector with your fingers to slowly pull them out.
Pull the motherboard to the right to clear the peripheral connections of the laptop casing.
Lift the motherboard out of the laptop.
