Ana içeriğe geç
ASUS E210MA-TB.CL464BK USB Port Replacement
Neye ihtiyacın var
  1. ASUS E210MA-TB.CL464BK USB Port Replacement, USB Port: adım 1, 3 resimden 1. ASUS E210MA-TB.CL464BK USB Port Replacement, USB Port: adım 1, 3 resimden 2. ASUS E210MA-TB.CL464BK USB Port Replacement, USB Port: adım 1, 3 resimden 3.
    • Place the laptop with the bottom side facing up. Have the front (where the touchpad is) facing toward you.
    • Start by removing the ten 7mm screws on the bottom of the laptop using a JIS #00 screwdriver.
  2. ASUS E210MA-TB.CL464BK USB Port Replacement: adım 2, 1 resimden 1.
    • Double-check to make sure all of the screws are removed.
    • If you have a Jimmy or other flat, straight-edge object, slide it in the crack where the halves of the case meet.
    • When the parts are separated, pull them apart to expose the insides of the case.
  3. ASUS E210MA-TB.CL464BK USB Port Replacement: adım 3, 2 resimden 1. ASUS E210MA-TB.CL464BK USB Port Replacement: adım 3, 2 resimden 2.
    • Remove the four 2 mm screws from the USB PCB.
  4. ASUS E210MA-TB.CL464BK USB Port Replacement: adım 4, 1 resimden 1.
    • Unlatch the ribbon cable from the the USB port and remove the PCB.
Sonuç
John Hutchins
763 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 73-6, Gonzalez Spring 2023 Gateway, Team 73-6, Gonzalez Spring 2023 üyesi
GCC-GONZALEZ-S23S73G6
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 138
