Giriş
Use this guide to replace the battery of your ASUS EEE PC701SD-WHI004X. Make sure to disconnect the adapter before beginning. You should be following this guide if the battery is dead, or the adapter has stopped charging the laptop.
Flip the laptop over, you should see two battery tabs.
Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
3 farklı kişi bu kılavuzu tamamladı.
