Ana içeriğe geç
ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement
Neye ihtiyacın var
    1. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement, Battery: adım 1, 2 resimden 1. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement, Battery: adım 1, 2 resimden 2.
      • Flip the laptop over, you should see two battery tabs.
      • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement: adım 2, 2 resimden 1. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement: adım 2, 2 resimden 2.
      • While holding the left tab towards the left. Gently slide the battery out of the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement, SSD: adım 3, 3 resimden 1. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement, SSD: adım 3, 3 resimden 2. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement, SSD: adım 3, 3 resimden 3.
      • Remove the two 2.5mm Phillips #1 screws.
      • Gently remove back panel by lifting the tab. This will expose the SSD.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement: adım 4, 1 resimden 1.
      • Unscrew the two 2.0mm Phillips #0 screws.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement: adım 5, 3 resimden 1. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement: adım 5, 3 resimden 2. ASUS EEE PC701SD-WHI004X HardDrive/SSD Replacement: adım 5, 3 resimden 3.
      • The SSD should now pop up.
      • Grasping the sides of the SSD, gently pull it out at the angle it makes with the device.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
mir
409 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G8, Isaacson Spring 2017 UMass Dartmouth, Team S2-G8, Isaacson Spring 2017 üyesi
UMASSD-ISAACSON-S17S2G8
3 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 56
Her zaman: 5,683
