Ana içeriğe geç
ASUS EEE PC701SD-WHI004X Keyboard Replacement
Neye ihtiyacın var
  1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: adım 1, 2 resimden 1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over, you should see two battery tabs.
    • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: adım 2, 2 resimden 1. ASUS EEE PC701SD-WHI004X Keyboard Replacement: adım 2, 2 resimden 2.
    • While holding the left tab towards the left. Gently slide the battery out of the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. ASUS EEE PC701SD-WHI004X Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Push the 3 tabs at the top of the keyboard in and down one at a time using a nylon spudger.
    • Once the three tabs have been pushed in, gently pry the top of the keyboard until it begins to hinge out of its slot.
    • The keyboard is still attached by a cable. Be careful when removing not to damage the cable. Do not yank the keyboard out.
    FixBot'a Sor
    Yorum Ekle
  4. ASUS EEE PC701SD-WHI004X Keyboard Replacement: adım 4, 3 resimden 1. ASUS EEE PC701SD-WHI004X Keyboard Replacement: adım 4, 3 resimden 2. ASUS EEE PC701SD-WHI004X Keyboard Replacement: adım 4, 3 resimden 3.
    • Push the two sides of the ribbon cable connector away from yourself. This will unseat the ribbon cable.
    • Once the tabs are unseated, you can gently remove the ribbon cable by pulling it out of its slot. The keyboard can now be removed.
    • To be on the safe side, it’s better to use a nylon spudger, rather than the metal spudger shown in the picture.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
mir
409 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G8, Isaacson Spring 2017 UMass Dartmouth, Team S2-G8, Isaacson Spring 2017 üyesi
UMASSD-ISAACSON-S17S2G8
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 31
Her zaman: 939
