Ana içeriğe geç
ASUS EEE PC701SD-WHI004X RAM Replacement
Neye ihtiyacın var
  1. ASUS EEE PC701SD-WHI004X RAM Replacement, Battery: adım 1, 2 resimden 1. ASUS EEE PC701SD-WHI004X RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over, you should see two battery tabs.
    • Slide the right tab towards the right. The orange dot should be visible. This tab will be locked open.
    FixBot'a Sor
    Yorum Ekle
  2. ASUS EEE PC701SD-WHI004X RAM Replacement: adım 2, 2 resimden 1. ASUS EEE PC701SD-WHI004X RAM Replacement: adım 2, 2 resimden 2.
    • While holding the left tab towards the left. Gently slide the battery out of the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. ASUS EEE PC701SD-WHI004X RAM Replacement, RAM: adım 3, 3 resimden 1. ASUS EEE PC701SD-WHI004X RAM Replacement, RAM: adım 3, 3 resimden 2. ASUS EEE PC701SD-WHI004X RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Remove the two 2.5mm Phillips #1 screws.
    • Remove back panel by lifting the tab, this will expose the RAM.
    FixBot'a Sor
    Yorum Ekle
  4. ASUS EEE PC701SD-WHI004X RAM Replacement: adım 4, 3 resimden 1. ASUS EEE PC701SD-WHI004X RAM Replacement: adım 4, 3 resimden 2. ASUS EEE PC701SD-WHI004X RAM Replacement: adım 4, 3 resimden 3.
    • Gently push the metal tabs outwards, this will allow the RAM to pop up.
    FixBot'a Sor
    Yorum Ekle
  5. ASUS EEE PC701SD-WHI004X RAM Replacement: adım 5, 2 resimden 1. ASUS EEE PC701SD-WHI004X RAM Replacement: adım 5, 2 resimden 2.
    • Remove the RAM stick by grabbing it on the sides and gently pulling the stick out of its slot.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Vinny Micale
225 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S2-G8, Isaacson Spring 2017 UMass Dartmouth, Team S2-G8, Isaacson Spring 2017 üyesi
UMASSD-ISAACSON-S17S2G8
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 674
