Ana içeriğe geç
ASUS Eee PC 1008ha Battery Replacement
Neye ihtiyacın var
    1. ASUS Eee PC 1008ha Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Using the plastic opening tool, carefully pry the top panel from the base.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS Eee PC 1008ha Battery Replacement: adım 2, 3 resimden 1. ASUS Eee PC 1008ha Battery Replacement: adım 2, 3 resimden 2. ASUS Eee PC 1008ha Battery Replacement: adım 2, 3 resimden 3.
      • Lift the side of the keyboard.
      • Disconnect the attached ribbon located underneath the keyboard.
      • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS Eee PC 1008ha Battery Replacement: adım 3, 2 resimden 1. ASUS Eee PC 1008ha Battery Replacement: adım 3, 2 resimden 2.
      • Use your fingers to lift the battery and gently disconnect the wires from the base.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Powers
101 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G52
4 Üyeler
17 adet Kılavuz yazıldı
4Kılavuz Yorumları
where could i find compatible batteries?
qforkyu - Yanıt Paylaş
Good question! Did you find one?
paulteale - Yanıt Paylaş
This guide is misleading. There is no way to do step 1 just from the front. At least I cannot do it and my notebook is already half open due to the swollen battery. Most guides show that you need to disassemble the whole thing.
For instance:
http://forum.notebookreview.com/asus/388...
cis - Yanıt Paylaş
Батарея состоит из трёх отдельных Li-ion аккумуляторов, соединённых через плату контроллера. Обычно вздувается один из трёх аккумуляторов. Надо разобрать ваш нетбук, как показано в видео:
https://www.youtube.com/watch?v=-3ipeduI...
Тогда надо её аккуратно выкусить и стараться не проколоть надутую батарею, потому что в ней много неприятного запаха. На её место можно поставить подходящий по толщине аккумулятор с напряжением 3.6 - 3.7V с током до 1000mA (1A) и обязательно соблюдать полярность при установке аккумулятора. Тогда вам будет счастье.
С уважением, устный переводчик синхронист.
Simultaneous Translation - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 10,991
