Ana içeriğe geç
ASUS Eee PC 1018P Battery Replacement
Neye ihtiyacın var
  1. ASUS Eee PC 1018P Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
  2. ASUS Eee PC 1018P Battery Replacement: adım 2, 2 resimden 1. ASUS Eee PC 1018P Battery Replacement: adım 2, 2 resimden 2.
    • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
  3. ASUS Eee PC 1018P Battery Replacement: adım 3, 3 resimden 1. ASUS Eee PC 1018P Battery Replacement: adım 3, 3 resimden 2. ASUS Eee PC 1018P Battery Replacement: adım 3, 3 resimden 3.
    • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
    • Pull the battery pack up and away from you to completely free it from its recess in the case.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Daniel Rodman
309 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-13, Maness Winter 2012 Cal Poly, Team 8-13, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G13
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 2,780
