Ana içeriğe geç
ASUS Eee PC 1018P RAM Replacement
Neye ihtiyacın var
    1. ASUS Eee PC 1018P RAM Replacement, Battery: adım 1, 1 resimden 1.
      • Lay the laptop flat on a hard surface with the bottom facing up and the battery pack on the side closest to you.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS Eee PC 1018P RAM Replacement: adım 2, 2 resimden 1. ASUS Eee PC 1018P RAM Replacement: adım 2, 2 resimden 2.
      • Use both index fingers to push both spring tabs inwards towards the center of the laptop.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS Eee PC 1018P RAM Replacement: adım 3, 3 resimden 1. ASUS Eee PC 1018P RAM Replacement: adım 3, 3 resimden 2. ASUS Eee PC 1018P RAM Replacement: adım 3, 3 resimden 3.
      • With the spring tabs pressed inward, use your fingernails to lift of the edge of the battery, pivoting it up and towards you.
      • Pull the battery pack up and away from you to completely free it from its recess in the case.
      FixBot'a Sor
      Yorum Ekle
    1. ASUS Eee PC 1018P RAM Replacement, RAM: adım 4, 1 resimden 1.
      • With the battery removed, locate the RAM cover.
      FixBot'a Sor
      Yorum Ekle
    2. ASUS Eee PC 1018P RAM Replacement: adım 5, 2 resimden 1. ASUS Eee PC 1018P RAM Replacement: adım 5, 2 resimden 2.
      • Use your thumb to pry up the exposed edge of the RAM cover. Once this edge is lifted, the cover will come free.
      • With the RAM cover removed, carefully peel back the silver foil that protects the RAM.
      FixBot'a Sor
      Yorum Ekle
    3. ASUS Eee PC 1018P RAM Replacement: adım 6, 2 resimden 1. ASUS Eee PC 1018P RAM Replacement: adım 6, 2 resimden 2.
      • Use the plastic opening tool to push aside the two silver tabs that hold down the RAM module.
      • In order to detach the tabs , use the plastic opening tool to pull the tab slightly toward the battery pack, then push outward away from the RAM module.
      • The RAM module will pop upward at a slight angle when both tabs are detached.
      FixBot'a Sor
      Yorum Ekle
    4. ASUS Eee PC 1018P RAM Replacement: adım 7, 2 resimden 1. ASUS Eee PC 1018P RAM Replacement: adım 7, 2 resimden 2.
      • Carefully grasping the edges of the RAM module, slowly pull it free from the pin connectors underneath the edge of the foil.
      • Pull the RAM out at the same angle that it pops up naturally to. Ripping the RAM free at other angles can damage the fragile pins.
      FixBot'a Sor
      Yorum Ekle
    5. ASUS Eee PC 1018P RAM Replacement: adım 8, 1 resimden 1.
      • Remove RAM module entirely for repair or replacement.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ekip
Cal Poly, Team 8-13, Maness Winter 2012 Cal Poly, Team 8-13, Maness Winter 2012 üyesi
CPSU-MANESS-W12S8G13
4 Üyeler
55 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 3,829
