Ana içeriğe geç
ASUS Eee PC 900HD Track Pad Replacement
Neye ihtiyacın var
  1. ASUS Eee PC 900HD Track Pad Replacement, Track Pad: adım 1, 3 resimden 1. ASUS Eee PC 900HD Track Pad Replacement, Track Pad: adım 1, 3 resimden 2. ASUS Eee PC 900HD Track Pad Replacement, Track Pad: adım 1, 3 resimden 3.
    • Flip the laptop over and locate the battery lock tabs.
    • Slide the right tab to the unlock position (right) so that a red dot is showing. Then, slide and hold the left tab to its unlock position (left).
    • Pull the battery out.
  2. ASUS Eee PC 900HD Track Pad Replacement: adım 2, 3 resimden 1. ASUS Eee PC 900HD Track Pad Replacement: adım 2, 3 resimden 2. ASUS Eee PC 900HD Track Pad Replacement: adım 2, 3 resimden 3.
    • Remove the four 4.76 mm screws using the Phillips J0 screwdriver.
    • Lift up on the hard drive cover to remove.
  3. ASUS Eee PC 900HD Track Pad Replacement: adım 3, 3 resimden 1. ASUS Eee PC 900HD Track Pad Replacement: adım 3, 3 resimden 2. ASUS Eee PC 900HD Track Pad Replacement: adım 3, 3 resimden 3.
    • Starting from the left, use a plastic opening tool to slide the hard drive all the way to the right.
    • Once the hard drive is all the way to the right, lift it up on the hard drive and pull it out.
  4. ASUS Eee PC 900HD Track Pad Replacement: adım 4, 1 resimden 1.
    • Remove the 4.76 mm screw under the hard drive using the Phillips J0 screwdriver.
  5. ASUS Eee PC 900HD Track Pad Replacement: adım 5, 2 resimden 1. ASUS Eee PC 900HD Track Pad Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Flip the laptop back over and unlock the three keyboard tabs at the top of the keyboard by pushing down on the silver tabs with tweezers .
  6. ASUS Eee PC 900HD Track Pad Replacement: adım 6, 2 resimden 1. ASUS Eee PC 900HD Track Pad Replacement: adım 6, 2 resimden 2.
    • Use the plastic opening tool to lift up the keyboard.
  7. ASUS Eee PC 900HD Track Pad Replacement: adım 7, 3 resimden 1. ASUS Eee PC 900HD Track Pad Replacement: adım 7, 3 resimden 2. ASUS Eee PC 900HD Track Pad Replacement: adım 7, 3 resimden 3.
    • Using a pair of tweezers, disconnect the cable at the bottom of the keyboard by flipping the two black lock switches up on both sides of the cable.
    • Carefully pull the cable out.
  8. ASUS Eee PC 900HD Track Pad Replacement: adım 8, 3 resimden 1. ASUS Eee PC 900HD Track Pad Replacement: adım 8, 3 resimden 2. ASUS Eee PC 900HD Track Pad Replacement: adım 8, 3 resimden 3.
    • Remove the nine 4.76 mm screws from the surface of the laptop using the Phillips J0 screwdriver.
    • Using a pair of tweezers, unlock the blue touch pad ribbon by pushing the white lock tab to the right.
  9. ASUS Eee PC 900HD Track Pad Replacement: adım 9, 2 resimden 1. ASUS Eee PC 900HD Track Pad Replacement: adım 9, 2 resimden 2.
    • Carefully pull the blue touchpad ribbon to the right.
  10. ASUS Eee PC 900HD Track Pad Replacement: adım 10, 3 resimden 1. ASUS Eee PC 900HD Track Pad Replacement: adım 10, 3 resimden 2. ASUS Eee PC 900HD Track Pad Replacement: adım 10, 3 resimden 3.
    • Using a plastic opening tool, remove the cover of the laptop by prying up the edges.
    • Be careful around the audio and microphone jacks as they can be easily damaged. Lift the right half of the cover and move it towards the left.
  11. ASUS Eee PC 900HD Track Pad Replacement: adım 11, 2 resimden 1. ASUS Eee PC 900HD Track Pad Replacement: adım 11, 2 resimden 2.
    • Lift up and remove the top cover of the laptop.
    • Flip this cover over to reveal the back.
  12. ASUS Eee PC 900HD Track Pad Replacement: adım 12, 2 resimden 1. ASUS Eee PC 900HD Track Pad Replacement: adım 12, 2 resimden 2.
    • Remove the two 4.76 mm screws using the Philips JO screwdriver.
  13. ASUS Eee PC 900HD Track Pad Replacement: adım 13, 3 resimden 1. ASUS Eee PC 900HD Track Pad Replacement: adım 13, 3 resimden 2. ASUS Eee PC 900HD Track Pad Replacement: adım 13, 3 resimden 3.
    • Using the plastic opening tool, gently pry the metal foil up around the edges of the trackpad.
    • Caution: Do not completely remove the foil.
    • Lift the metal plate up to expose the trackpad.
    • Now you can safely remove the track pad.
Sonuç
Kendall Marie Mehlhorn
572 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 492
