Ana içeriğe geç
ASUS Eee Pad Transformer Back Facing Camera Replacement
Neye ihtiyacın var
  1. ASUS Eee Pad Transformer Back Facing Camera Replacement, Back Panel: adım 1, 2 resimden 1. ASUS Eee Pad Transformer Back Facing Camera Replacement, Back Panel: adım 1, 2 resimden 2.
    • Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
  2. ASUS Eee Pad Transformer Back Facing Camera Replacement: adım 2, 3 resimden 1. ASUS Eee Pad Transformer Back Facing Camera Replacement: adım 2, 3 resimden 2. ASUS Eee Pad Transformer Back Facing Camera Replacement: adım 2, 3 resimden 3.
    • Use the Plastic Opening Tool to pry between the main tablet body and the outer rim casing. Remove the outer rim casing by prying all the way around the device and pulling the rim upward.
    • The physical buttons are located on the outside of the rim on the right side, proceed with the guide to locate internal buttons.
  3. ASUS Eee Pad Transformer Back Facing Camera Replacement: adım 3, 1 resimden 1.
    • Remove the four 2 millimeter Phillips #00 screws at the corners of the tablet.
  4. ASUS Eee Pad Transformer Back Facing Camera Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found above the camera area, on the top portion of the tablet.
  5. ASUS Eee Pad Transformer Back Facing Camera Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #00 Screwdriver to remove the three 3 millimeter screws securing the front panel to the back panel found on the bottom portion of the tablet near the port.
  6. ASUS Eee Pad Transformer Back Facing Camera Replacement: adım 6, 2 resimden 1. ASUS Eee Pad Transformer Back Facing Camera Replacement: adım 6, 2 resimden 2.
    • Remove back panel by pulling away from the remaining device.
  7. ASUS Eee Pad Transformer Back Facing Camera Replacement, Pull out flap: adım 7, 2 resimden 1. ASUS Eee Pad Transformer Back Facing Camera Replacement, Pull out flap: adım 7, 2 resimden 2.
    • Use Tweezers to pull out gold flap connected to bottom of camera.
    • Pull the gold flap to take out the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sandy Babich
1.885 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-9, Forte Fall 2014 Cal Poly, Team 13-9, Forte Fall 2014 üyesi
CPSU-FORTE-F14S13G9
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 1,120
