Giriş
Is the GPS in your ASUS Eee Pad Transformer no longer giving the accurate location of your device? If so, the GPS antenna may need replaced. Here is the guide to replace the GPS antenna. All you need is a Phillips #0 Screwdriver and T5 Torx Screwdriver to remove the screws, a Plastic Opening Tool to remove the plastic border, a Jimmy to pry the GPS antenna off, and tweezers to remove the connection wires.
Neye ihtiyacın var
Use T5 Torx Screwdriver to remove two 4.5 millimeter T5 screws on either side of the port on the bottom of the tablet.
