Neye ihtiyacın var
Remove the battery, using release clips.
Remove either 2 (or 4 for a full teardown) 12mm phillips screws, then removing the bottom cover to gain access to the HDD and RAM.
Remove HDD and RAM cover
Remove 3 5mm Phillips screws
Slide HDD caddy back, remove using the black pull tab.
5 farklı kişi bu kılavuzu tamamladı.
