Ana içeriğe geç
ASUS F555UA-EH71 Battery Replacement
Neye ihtiyacın var
  1. ASUS F555UA-EH71 Battery Replacement, Keyboard Panel: adım 1, 1 resimden 1.
    • Remove the ten 18 mm screws holding down the outer shell of the laptop using the Phillips #000 screwdriver.
  2. ASUS F555UA-EH71 Battery Replacement: adım 2, 2 resimden 1. ASUS F555UA-EH71 Battery Replacement: adım 2, 2 resimden 2.
    • Use your fingers to gently pry open the gap between the silver and black parts of the casing.
    • Separate the keyboard panel from the body of the laptop by wedging the iFixit Opening Tool in between the keyboard panel and the body.
    • The teeth of the casing should make a clicking noise as they’re pulled apart.
  3. ASUS F555UA-EH71 Battery Replacement: adım 3, 1 resimden 1.
    • Gently open the casing until the white, silver, and gold power strips are visible. Gently peel the strips from the bottom side of the laptop.
    • Disconnect the two cables connecting the keyboard panel to the laptop.
  4. ASUS F555UA-EH71 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the keyboard panel from the laptop.
  5. ASUS F555UA-EH71 Battery Replacement, Battery: adım 5, 3 resimden 1. ASUS F555UA-EH71 Battery Replacement, Battery: adım 5, 3 resimden 2. ASUS F555UA-EH71 Battery Replacement, Battery: adım 5, 3 resimden 3.
    • Use the Phillips #000 screwdriver to remove the eight 4 mm screws holding the battery in place.
  6. ASUS F555UA-EH71 Battery Replacement: adım 6, 2 resimden 1. ASUS F555UA-EH71 Battery Replacement: adım 6, 2 resimden 2.
    • Carefully remove the battery from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 978
