Giriş
If you wish to replace or upgrade your CD Drive, use this guide to do so. Replacing a CD Drive is relatively straightforward, and there are only a few parts that need to be removed to complete this task. It is difficult to repair the CD Drive itself, so it’s best to replace the whole thing if you find that the CD Drive is not working.
Neye ihtiyacın var
Remove the black 18 mm screws from the back panel of the laptop using the #000 Phillips screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
