Ana içeriğe geç
ASUS F555UA-EH71 LCD Screen Replacement
Neye ihtiyacın var
  1. ASUS F555UA-EH71 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Use a Jimmy to separate the outer panel of the monitor from the bezel. This is accomplished by wedging the tool in the small crease and pulling apart.
  2. ASUS F555UA-EH71 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Use a Jimmy to take off the two black, square stickers on the bottom left and right corner of the bezel. This will reveal two screws that are holding the bezel in place.
    • Use the Phillips #0 Screwdriver to take the two black 4 mm screws out.
  3. ASUS F555UA-EH71 LCD Screen Replacement: adım 3, 2 resimden 1. ASUS F555UA-EH71 LCD Screen Replacement: adım 3, 2 resimden 2.
    • To remove the bezel and gain access to the LCD screen, place your thumbs over the two holes where the screws used to be, and apply pressure.
    • Then, simultaneously apply pressure and push the upwards and the bezel will side off.
    • Once released, the bezel will lift off freely from the face of the screen.
  4. ASUS F555UA-EH71 LCD Screen Replacement: adım 4, 3 resimden 1. ASUS F555UA-EH71 LCD Screen Replacement: adım 4, 3 resimden 2. ASUS F555UA-EH71 LCD Screen Replacement: adım 4, 3 resimden 3.
    • To remove the LCD screen, use a Phillips #00 Screwdriver to unscrew the silver screws directly above and below the four corners of the screen.
    • Repeat this for the bottom left and top right sides of the screen.
  5. ASUS F555UA-EH71 LCD Screen Replacement: adım 5, 2 resimden 1. ASUS F555UA-EH71 LCD Screen Replacement: adım 5, 2 resimden 2.
    • Using your hands, carefully lift the screen from its housing and lay it flat on the keyboard.
  6. ASUS F555UA-EH71 LCD Screen Replacement: adım 6, 3 resimden 1. ASUS F555UA-EH71 LCD Screen Replacement: adım 6, 3 resimden 2. ASUS F555UA-EH71 LCD Screen Replacement: adım 6, 3 resimden 3.
    • Remove the scotch tape that is on the bottom of the backside of the screen. This will expose the cable that is connected to the screen.
    • Carefully disconnect this cable in order to free the LCD screen.
Sonuç
To reassemble your ASUS F555UA-EH71 laptop , follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 10
Her zaman: 471
