Ana içeriğe geç
ASUS G73JH-BST7 SD Hard Drive Replacement
Neye ihtiyacın var
  1. ASUS G73JH-BST7 SD Hard Drive Replacement, Battery: adım 1, 2 resimden 1. ASUS G73JH-BST7 SD Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the computer over, so that the bottom is facing up.
  2. ASUS G73JH-BST7 SD Hard Drive Replacement: adım 2, 3 resimden 1. ASUS G73JH-BST7 SD Hard Drive Replacement: adım 2, 3 resimden 2. ASUS G73JH-BST7 SD Hard Drive Replacement: adım 2, 3 resimden 3.
    • Slide the two tabs away from the battery.
    • The left tab will lock, but the right tab must be held away from the battery.
  3. ASUS G73JH-BST7 SD Hard Drive Replacement: adım 3, 3 resimden 1. ASUS G73JH-BST7 SD Hard Drive Replacement: adım 3, 3 resimden 2. ASUS G73JH-BST7 SD Hard Drive Replacement: adım 3, 3 resimden 3.
    • Use one hand to hold the non-locking tab in place, and use your other hand to pull the battery away from the computer.
  4. ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: adım 4, 3 resimden 1. ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: adım 4, 3 resimden 2. ASUS G73JH-BST7 SD Hard Drive Replacement, Back Panel: adım 4, 3 resimden 3.
    • With the bottom of the computer facing up, remove the two 7.1 mm screws using a Phillips #00 screwdriver.
  5. ASUS G73JH-BST7 SD Hard Drive Replacement: adım 5, 3 resimden 1. ASUS G73JH-BST7 SD Hard Drive Replacement: adım 5, 3 resimden 2. ASUS G73JH-BST7 SD Hard Drive Replacement: adım 5, 3 resimden 3.
    • Carefully pry the panel away from the computer, by lifting with a finger.
    • There is a small tab where a finger will fit to lift the panel away from the computer.
  6. ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: adım 6, 3 resimden 1. ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: adım 6, 3 resimden 2. ASUS G73JH-BST7 SD Hard Drive Replacement, SD Hard Drive: adım 6, 3 resimden 3.
    • Gently pull on the tabs to lift the SD Hard Drives out of the computer.
Sonuç
Deven Rodgers
253 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 396
