Ana içeriğe geç
ASUS GL752VW-DH74 SSD Replacement
Neye ihtiyacın var
  1. ASUS GL752VW-DH74 SSD Replacement, SSD: adım 1, 1 resimden 1.
    • Unscrew both 8mm phillip's head screws that hold on the access gate.
  2. ASUS GL752VW-DH74 SSD Replacement: adım 2, 1 resimden 1.
    • Use either the your finger, the screw driver, or a spudger to pop out the gate.
  3. ASUS GL752VW-DH74 SSD Replacement: adım 3, 1 resimden 1.
    • From here, you can access the hardrive, motherboard, SSD, and RAM.
  4. ASUS GL752VW-DH74 SSD Replacement: adım 4, 1 resimden 1.
    • Remove the 4mm screw holding in the SSD.
    • Note that the screw is holding it down so it will pop up once the screw is removed.
  5. ASUS GL752VW-DH74 SSD Replacement: adım 5, 1 resimden 1.
    • Remove SSD from slot.
Sonuç
Ralph Lopez
202 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 UMass Dartmouth, Team S1-G3, Isaacson Fall 2017 üyesi
UMASSD-ISAACSON-F17S1G3
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,583
