Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
With the opening facing you, flip the laptop over and remove the following screws from the back panel:
Six 4mm Phillips screws using a Phillips #0 screwdriver.
One 12mm Phillips screw in the center using a Phillips #0 screwdriver.
Using a plastic spudger, remove the two rubber stoppers closest to the hinge to reveal the screws underneath.
Remove the following screws:
Two 4mm Phillips screws using a Phillips #0 screwdriver.
Using a plastic spudger (and a fair amount of force), pry the back panel up from the keyboard to separate.
